What is shortcuts and bottom corners for on my phone? And if I don't how can I unstall it?
hallux
Q&A Team
Jul 7, 2013
12,322
7
38
Is this an app you're seeing? Some function you're seeing in settings? Where are you seeing this that it has you concerned?
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,388
253
83
They are optional customisable lockscreen shortcuts, allowing you to perform certain actions directly from the lockscreen.
Javier P
Ambassador
Feb 21, 2014
19,480
3
Welcome to the forums. Do you mean the small curved lines at the bottom corners? If so, they are just reminders for the Google Assistant gestures. They should disappear in a couple of days or after you use them.
Which phone and Android version are you using?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,587
4,728
113
Welcome to Android Central! It's been 4 days, and you've gotten 3 responses. Please answer us.;)
Nikoczzzz
