Originally Posted by
SpookDroid Bear in mind that if the device supports talkback (and the accessibility shortcut was enabled), this would only, well, talk back with descriptions of what should be on the screen. You still need a way to provide input (i.e. external mouse/keyboard) and a fair understanding of what exactly are you looking for on the screen or this will become very tedious, very fast.
For the purpose the OP needs this (fully functional phone for work and not just for a quick back up), this wouldn't be practical in the long run.
That is true, but I also think it's moot. Personally I think using a phone that doesn't have a screen in the long-run isn't really practical. Whether the Opie likes it or not, what they need is a new phone or a screen replacement.
Besides, I was specifically talking about using a keyboard and talkback to get the thing set up to use USB debugging and be controlled by PC. That's why I quoted loneninja. Because I was specifically responding to their comment.
