1. rupeshforu3's Avatar
    Hi I am Rupesh from India and I want to buy a new tablet with low specifications but with high resolution display with qhd+ type.
    At present Apple ipad has the highest resolution with DCI-P3 feature. But I can't spend 50000 to 60000 and so I am searching for android tablet.
    I found that Xiaomi pad 5 has similar features like DCI-P3 and wqhd+ display and it costs around 26000.
    Still I want a new tablet with even lower spec but with qhd+ resolution and if possible OLED display.
    I found OLED display tablet from lenevo ie., Lenevo tab p11 pro, lenevo p12 pro etc., but it's cost is around 27000.
    All of the above comes with octa core processors like Qualcomm 860 etc., and has nice features but costs lot.
    My requirement is I want a new tablet with quad core processor, 1gb to 2gb ram, micro SD card support but with high resolution display and if possible OLED display.
    I found realme tab which has WUXGA display and nokia tab T20 which has 2k resolution.
    Mainly I want to read ebooks and so low resolution display can cause eye strain. Rarely I will see movies.
    Can anyone of you suggest a new android tablet with high resolution display and with atleast qhd+ display type, quad core processor is enough as it cost less.
    Regards,
    Rupesh.
    06-26-2022 11:37 AM
  2. fuzzylumpkin's Avatar
    Sounds like what you need is a Kindle.
    I don't think you'll get a crappy tablet with a good screen, good screens are expensive, so it isn't really feasible to put them on budget devices.
    Laura Knotek likes this.
    06-26-2022 02:58 PM
  3. rupeshforu3's Avatar
    Xiaomi pad 5 is in competition with iPad and costs half the price of ipad.
    I want to know any other tablet with highest quality display.
    06-26-2022 08:36 PM
  4. fuzzylumpkin's Avatar
    Buy that then.
    06-27-2022 06:03 AM
  5. rupeshforu3's Avatar
    Someone suggested Kindle fire but I have searched and found that it comes with 6.8 inch and 7 inch screen.
    Is there any Kindle fire tablet with 8 inch.
    They have even suggested ink reader tablets but I have not heard the word upto now and so can you suggest the names of some ink reader tablets.
    06-27-2022 07:06 AM
  6. fuzzylumpkin's Avatar
    They do make an 8 inch kindle fire, but I've got no idea if they sell them in india. the best ereader, which I believe is what is meant by ink reader, wwould be a non-fire kindle. the paperwhite is apparently very good for reading, but you can't watch movies on them.
    06-27-2022 07:14 AM
  7. rupeshforu3's Avatar
    May I know about ink reader tablets with names. I have not heard about them upto now. Does these have display which impose less strain to eye's.
    06-27-2022 08:47 AM
  8. B. Diddy's Avatar
    You may want to consider a Chromebook tablet, which can run Android apps. The HP Chromebook X2 11 has a QHD+ display, and gets a lot of good reviews: http://www.hp.com/us-en/chrome/chrom...ch-laptop.html
    06-27-2022 09:48 AM
  9. rupeshforu3's Avatar
    Hi upto now I have seen specs of a number of tablets and found that nokia tab T20 has 2k resolution which is approximately equal to qhd.
    Here 2k resolution has 2000 pixels and qhd has 2500 pixels.
    So I think it is better to choose nokia tab T20 as it comes reasonable price than other's.
    06-27-2022 09:59 AM
  10. rupeshforu3's Avatar
    Hi all of you actually I am searching for a tablet with display which impose less strain on eyes.
    I thought that qhd enabled tablet cause less strain to eye's.
    I have seen the specs of realme pad and nokia tab T20 and T20 tab has 2k high resolution and other specs are acceptable to me.
    Good display tablets cost a lot and so can I buy nokia tab T20.
    06-27-2022 11:35 AM
  11. rupeshforu3's Avatar
    Hi I heard that amoled display has been integrated into android smartphone.
    May I know which tablets has been released with amoled display.
    07-05-2022 09:23 AM
  12. mustang7757's Avatar
    Usually Samsung are AMOLED but whatever tablet your searching for under specs should mention which panel they are using
    07-05-2022 09:32 AM
  1. Replies: 2
    Last Post: 06-27-2022, 01:34 PM
  2. Why moto g power 2021 has apps with a 2008 install date
    Last Post: 06-27-2022, 01:00 PM
  3. Why i cant deactivate security plugin on my Android
    Last Post: 06-25-2022, 04:03 AM
  4. How do i access developer options on Android 13
    Last Post: 06-23-2022, 02:29 PM
  5. S22 Ultra Clear Case with integrated magnet mount
    By goldenzrule in forum Ask a Question
    Last Post: 06-22-2022, 07:36 PM
