1. acsurfer's Avatar
    Hello,
    Halfway during video recording using the default Samsung Note 8 Camera app, a file is sent to me via bluetooth (there will be a popup something like asking me to accept or decline the file). Once I press accept or decline the incoming file, the video will auto stop recording immediately.
    Q1. How to prevent video from stopping recording in the above situation?
    Q2. Does incoming call or pressing accept/decline incoming call auto stop video recording?
    Thanks
    08-12-2022 09:43 AM
  2. B. Diddy's Avatar
    I'm not sure about your second question, but you could always turn on Do Not Disturb temporarily while recording to prevent any other notifications from interrupting.
    acsurfer likes this.
    08-12-2022 10:51 AM
  3. mustang7757's Avatar
    Probably because video wants access to microphone and prioritize the calling, try B. Diddy suggestion
    08-12-2022 07:23 PM
  4. acsurfer's Avatar
    I there some sort of app/way that could problem once I use camera app it would auto enable Do Not Disturb, and once I close camera app it would disable Do Not Disturb?
    Is there alternative camera that would auto put camera in top priority to prevent interruption?
    Is there app that can show a banner/alert across the screen [do not disturb] is in use? In the past I used airplane mode and completely forget about airplane mode was on.
    Is there app that can set a timer how long [do not disturb] will be enabled?
    What is the difference of Do Not Disturb vs Airplane
    My second questions meaning halfway during recording a video using camera app, if there is someone calling my number there would be a incoming call screen, so when that happens I wonder if the video recording would auto stop when there is a incoming call?
    08-12-2022 08:29 PM
  5. acsurfer's Avatar
    Now it depends on luck and timing to be able to reply. You guys should inform the site owner about the problem of unable to reply. I guess other users might not be able to reply and leave. The problem of unable to reply happens again before I am able to reply.
    Video recording problem-screencapture-forums-androidcentral-general-help-how-1048325-video-recording-problem-html-2022-0.jpg
    08-12-2022 08:32 PM
  6. mustang7757's Avatar
    DND you can customize take a look at it's settings, as for replying here I'm not seeing a issue through chrome or Forums app , but if you like try the mobile Forum app as it's more user friendly to some
    https://forums.androidcentral.com/e?...token=Bq0zK3n8
    08-12-2022 09:47 PM
  7. B. Diddy's Avatar
    You could try an app like Tasker or IFTTT to see if they let you set up conditions for when to turn on DND that aren't otherwise native to the system.
    The format of the post in your screenshot is the Q&A format. I thought I had discussed this with you in the recent past, but maybe it was someone else. It's an odd format that doesn't let anyone reply. I don't know why the site admins keep this format around, but if you see it, then bring up the URL and delete everything after "html", then hit Enter. That should reload the page with the normal formatting.
    08-13-2022 12:53 AM
  1. MMS Video Comes In As Photo & Audio
    Last Post: 08-15-2022, 11:43 PM
  2. There was a problem parsing the package
    By paparazzo79 in forum Android Apps
    Last Post: 08-13-2022, 07:06 AM
  3. What is the best app/software for Video editing?
    By DRock910 in forum Android Apps
    Last Post: 08-11-2022, 06:56 PM
  4. Replies: 8
    Last Post: 08-11-2022, 12:20 PM
  5. Quick share videos from S22 Ultra to ZFold3
    By pdub73 in forum Samsung Galaxy Z Fold 3
    Last Post: 08-10-2022, 10:48 AM
