1. darryldayton's Avatar
    I have a new Samsung phone that has a larger charging port than my old Samsung phone I need to pair the two phones and need a cord with two different size male ends
    09-24-2022 03:11 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you mean a USB-C to microUSB-A cable, like this one? https://www.amazon.com/Cable-Matters...cUvbUpU7103614
    Laura Knotek likes this.
    09-24-2022 06:15 PM
  3. mustang7757's Avatar
    09-24-2022 07:48 PM
  4. fuzzylumpkin's Avatar
    What B.Diddy said, but you'd be better either transfering wirelessly or using smart switch to do a backup to external storage or a computer and then restoring from that.
    B. Diddy likes this.
    09-25-2022 03:42 AM
  5. B. Diddy's Avatar
    I was assuming the OP wanted to use Smart Switch with a cable ...
    09-25-2022 01:15 PM
  6. mustang7757's Avatar
    Thats what it sounded like to me
    09-25-2022 01:33 PM
  7. darryldayton's Avatar
    I don’t know the “lingo” as to what each of them are called. My old phone (about 2 years old) has the standard for the time size port, my new phone has the current size larger port. Therefore I really don’t know what to ask for.
    09-25-2022 01:35 PM
  8. B. Diddy's Avatar
    I merged your 2nd thread into your first one. Were you aware we had already responded?
    09-25-2022 01:41 PM
  9. tismydroid's Avatar
    What phones do you have? Depending on the phones you have, most likely the newest phone has a usb-C charging port. If the older phone is an Android then it most likely has a micro-usb port. If it's an iPhone then it would have a lightning port
    09-25-2022 01:46 PM
  10. tismydroid's Avatar
    Nevermind, it appears everyone has this covered.
    mustang7757 likes this.
    09-25-2022 01:47 PM
  11. fuzzylumpkin's Avatar
    Yeah, You were just answering the question that was asked.
    But the OP may not realise that there's a better option that doesnt involve buying and waiting for a cable that will be useful exactly once and then become eWaste.
    09-25-2022 02:35 PM
  12. mustang7757's Avatar
    Knowing which device we can lead u in right direction
    09-25-2022 05:21 PM
  13. darryldayton's Avatar
    Both are Samsung androids.
    09-25-2022 09:44 PM
  14. mustang7757's Avatar
    Samsung makes lots of device's , be more specific
    09-25-2022 09:50 PM
  15. mustang7757's Avatar
    09-25-2022 09:51 PM
  16. B. Diddy's Avatar
    Can you also clarify -- are you trying to transfer data using Smart Switch? If so, did you see fuzzylumpkin's suggestion about wireless transfer?
    http://www.samsung.com/us/support/ow...p/smart-switch
    09-25-2022 10:00 PM
  17. darryldayton's Avatar
    www.samsung.com/us/support/owners/app/smart-switch
    No, not using Smart Switch as that is currently not an option, long story.
    09-25-2022 10:10 PM
  18. mustang7757's Avatar
    Don't know the models you have?
    09-25-2022 11:03 PM
  19. B. Diddy's Avatar
    So you're just trying to manually transfer data using a cable?
    As mustang7757 has been asking, it'd be helpful to know which Samsung devices you're talking about.
    09-25-2022 11:23 PM
  20. mustang7757's Avatar
    This will go into another day
    09-25-2022 11:31 PM
  21. Ben xfg's Avatar
    Post pictures of both charge ports and we'll be able to see.
    09-26-2022 12:01 AM
  22. darryldayton's Avatar
    UPDATE:
    Thanks to all for your help. I got the correct cord and got everything transferred to the new phone.
    Laura Knotek and B. Diddy like this.
    09-27-2022 02:45 PM
  23. Laura Knotek's Avatar
    UPDATE:
    I'm glad you got everything sorted.
    09-27-2022 03:55 PM
  1. What camera lens does S22 Ultra use for video recording?
    By Android Central Question in forum Samsung Galaxy S22 & S22+ & S22 Ultra
    Last Post: 09-24-2022, 08:38 AM
  2. Number ported? What is this mystery text message?
    Last Post: 06-19-2019, 05:23 PM
