I have searched a good bit and cannot find this anywhere. I recently found that when I swipe to dial contacts with my captivate (running serendipity 6.4 and speedmod k13e) some of the numbers will not dial. They will not dial because the dialer is adding "##" to the beginning of the number and the phone does not recognize them as valid numbers. I have checked my auto dial, fdn, location settings, etc, and can't find any obvious cause. If i "edit before dialing" the number and take out the ## it dials fine. Any ideas? Thanks
