Hello my name is Ryan, I have a problem. I had rooted LG Optimus and it worked out really well for me. Last night however, I made a big mistake. I wanted to unroot because I was going to return my phone, so I deleted Super User using uninstaller application, and then proceded to do a factory reset. Now I am stuck in clock work recovery mode. I have tried restoring from previous images, I have tried flashing stock roms. I have cleared the cache etc, the results are all the same stock rom doesn't install and a rebook always takes me back to the clockwork recovery mod. Please help
I am worried that in clockwork with out SU Permission I have a $150 light weight brick, is there a way to add SU Permission or remove clockwork recovery so I can flash a stock rom provided the one's I have are indeed stock? I can return this to Best Buy but I don't want them to turn on the power even though they likely wont.
Check my posting about a week ago. There's a link I posted about how to get your Optims V back to working order.
