1. Tech2011's Avatar
    Hello!
    I have an HTC Evo 4G running stock Android 2.2, after factory-resetting my device because of a bad ROM I installed. So now I'm running stock Froyo on my Evo and I try to run Plants Vs Zombies and it crashes at the hourglass loading sign and then it crashes and goes back to the previous screen prior to opening the app. It was working just fine under Gingerbread 2.3 OTA, but for some reason does not work on Froyo OTA. Is anyone else experiencing this problem? Any help would be most certainly appreciated! Thanks!
    08-16-2011 01:00 PM
  2. Tech2011's Avatar
    Update -- I moved Plants Vs Zombies to SD card and it works now. No crashing! Ya!
    08-16-2011 01:07 PM
  3. amhickox's Avatar
    I have the same problem... will moving the game make me lose all my game data?
    08-28-2013 05:03 AM
  4. amhickox's Avatar
    Update. I tried and it still doesn't work.
    08-28-2013 05:19 AM
