1. Mr One 2#AC's Avatar
    I have rooted my dx2. I checked for updates in the menu, and over night it downloaded it and keeps asking to install now. Is there a way to get did of the update now or install later prompt. newbie to android here! Tia!
    08-20-2011 10:37 AM
  2. Moscow Desire's Avatar
    If you install the update, you might lose root access.
    To get rid of the "install now", you'll probably need to delete it (update file), from your sd card. It's usually named update.zip. Or something similar. Then reboot the phone.
    See if that fixes it.
    And turn your system updates to Off. And don't go looking for stock updates, unless you want to lose your root.
    08-20-2011 10:59 AM
