1. rdicarlo's Avatar
    I have a new archos 7 tablet. When I try to load apps the market tells me there is not a phone # associated with the account. I try to use my Gmail account it tries to send the app to my phone. How do I get apps on that tablet. I'm new to android, so if more infoi will do my best to find it. Thanks
    08-21-2011 09:41 AM
  2. Bendroid55's Avatar
    You should be able to just click download in the market and the app should install automatically. It sounds like the device is not recognizing your google account. Go to Settings/Accounts & Sync and make sure there is a valid gmail account there, if not add one. If all else fails try a factory reset.
    08-21-2011 02:36 PM
  3. ls377's Avatar
    The older gen archos tablets don't have the market or gmail on them, so you have to install the right files to get it to work.
    Try the fourth post here:http:// http://forum.archosfans.com/viewtopic.php?f=73&t=39792
    08-21-2011 02:39 PM
  4. Bendroid55's Avatar
    Seriously?
    08-21-2011 02:46 PM
  5. ls377's Avatar
    Seriously?
    No, totally just made it up. . [/sarcasm]
    It's pretty common on pre-HC tablets, but there's usually a workaround. Definitely worth it for the price difference from the Galaxy Tab 7.
    08-21-2011 02:55 PM
  6. Bendroid55's Avatar
    Haha. Interesting.
    08-21-2011 06:14 PM
