1. wrapman's Avatar
    Hello. I was able to install the Android Market on computer running Android-x86 2.3.5, but since it isn't an official build of Android, I can't login to Google. I hear there is an exploit where you can login through Google Talk, but I have had trouble installing that. I installed Talk.apk, but Talk crashes when I try to install it. When I try to install googletalkservice.apk, it says application not installed. Can anyone help with this?
    08-25-2011 02:43 PM
  2. wrapman's Avatar
    Oh, and also, does anyone have an empty MasterCard or Visa gift card? I need one for the Amazon App Store.
    08-25-2011 03:14 PM
