Keyboard problem
btamez723
I have the Inspire, and today I noticed a couple of keys on the keyboard have stopped working. I have tried other keyboards and everything, restarted the phone, nothing works. My "i" key doesn't work, and when I go to the number pad still in text mode the 8 doesn't work, which is in the same spot. What do I do?? I've only had this phone 2 weeks....
Moscow Desire
Troubleshooter
Mar 3, 2011
1,801
135
If you haven't rooted and/or installed a custom Rom, You should turn it in for a replacement.
You could do a factory reset (read the instructions for your device), but this sounds like a hardware issue.
Backup-up your contacts first before doing either of the above.
It happens.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Does the screen respond in that general area? From the other keyboard you've used, are the same keys i and 8 in the same general area?
My suggestion is to factory reset and try again. If it persist take it back, assuming it was purchased at a store.
Moscow Desire
Troubleshooter
Mar 3, 2011
1,801
135
You are quick, Moscow. I was thinking it might be a hardware issue as well.
Not quick, I just wake earlier than you and have a caffiene IV ;)
Besides, if it's a new device, and it's stock, I'd take it back whilst the sales rep still remembers me! Note to new device buyers ;)
Suppose AC should give both of us one of those fancy background images on our profile by now ;)
