main.xml:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="[http prefix]schemas.android.com/apk/res/android"
android:id="@+id/LinearLayout01"
android:layout_height="100dp"
android:background="@drawable/background"
android:layout_width="320dp"
android:weightSum="1" androidrientation="horizontal" android:baselineAligned="true">
<ToggleButton android:id="@+id/WiFi" android:text="ToggleButton" android:layout_width="wrap_content" android:layout_height="wrap_content" android:layout_marginLeft="20dip" android:layout_marginTop="45dip"></ToggleButton>
<ToggleButton android:id="@+id/3G" android:text="ToggleButton" android:layout_width="wrap_content" android:layout_height="wrap_content" android:layout_marginLeft="10dip" android:layout_marginTop="45dip"></ToggleButton>
<ToggleButton android:id="@+id/GPS" android:text="ToggleButton" android:layout_width="wrap_content" android:layout_height="wrap_content" android:layout_marginLeft="12dip" android:layout_marginTop="45dip"></ToggleButton>
</LinearLayout>
SettingsActivity.java:
package com.ipp.ssw.sigsetwig;
import android.R;
import android.app.Activity;
import android.content.Intent;
import android.os.Bundle;
import android.os.Debug;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.CompoundButton;
import android.widget.ToggleButton;
public class SignalSettingsActivity extends Activity implements OnClickListener
@Override
public void onCreate(Bundle savedInstanceState)
super.onCreate(savedInstanceState);
setContentView(com.ipp.ssw.sigsetwig.R.layout.main);
public void onClick( View v )
ToggleButton WiFiToggle = (ToggleButton)findViewById(R.id.WiFi);
WiFiToggle.setOnClickListener(this);
switch( v.getId() )
case R.id.WiFi:
if( WiFiToggle.isChecked() == true )
if( WiFiToggle.isChecked() == false )
break;
default:
break;
All UNDERLINED items are errors...
the @drawable/background gives:
Error: No resource found that matches the given name (at 'background' with value '@drawable/background'). Android AAPT Problem. - Fixed
all others give:
WiFi cannot be resolved or is not a field. Java Problem.
</LinearLayout>
import android.R;
@Override
switch( v.getId() )
case R.id.WiFi:
break;
default:
break;
all others give:
Any help is appreciated,
IP Programs
IP Programs
