1. Hatchm022's Avatar
    I have the following pad and need suggestions on how to improve preformance;
    Android SuperPad; Model # P001:JUTWNIA; VERSION - 2.2V2.5#4325; KERNRL VERSION- 2.6.32.9 Judy@JUDY-PC#26; Build# FRF85B
    Thanks to All in advance for your advice and help
    Hatchmo
    10-15-2011 08:11 PM
  2. Moscow Desire's Avatar
    First, you'll need to "root" the device. I found this link that "might" work on your device, but you should check and see if there are other rooting options.
    Easy “ROOT” procedure for SuperPAD (Flytouch 2) - Android Forums
    Now, this is not going to increase performance, but, it opens the door to installing a custom ROM for example, which usually increases performance. Also overclocking the cpu. Or removing maybe some preinstalled apps you don't want (be careful not to remove system apps)
    Please note, that I'm not responsible if things go wrong, and sometimes it happens. I'm just providing you info. Also note, rooting voids your warranty (but usually they don't notice it)
    Here at AC, there are some threads that cover basic info on rooting and custom roms. Suggest you read them and then decide if you wish to go that direction.
    One more note. Once you root, it is not advisable to take OTA updates. But then again, if you flash custom roms, you usually get the updated android version anyhow.
    10-16-2011 02:02 AM
  3. Phil T's Avatar
    This is a big help. Many thanks. Now where can I find info to find and install rom updates etc please
    11-25-2011 09:28 AM
