When I'm playing music with spotify through bluetooth and disconnect the bluetooth device (ie. turn off my car), spotify pauses the song which is normal. Then if I go to play the song again, no matter how soon or long after, the song wont play and the "play slider" thing goes to the beginning of the song. I have to touch any point in the slider and it will start playing again. This is annoying because I have to unlock my phone and go into the app to do this, instead of simply hitting play on the widget on my lockscreen or play on my car stereo once bt is connected. Any tips? I'm running CM7 on DINC.
Another (un?)related issue with spotify is how it goes offline when I'm done using it so I cant just hit play again on the widget to pick up where it left off. Any way to make it 'remember' what song was playing and start at that song again when I press play?
Thanks guys!
Thanks guys!
