1. siwel1976's Avatar
    I downloaded some audio files to my Atrix phone and I press the Music app to hear it. However the files plays for a few minutes then it stops. I cleared the data and the cache. Any idea how I can stop this?
    10-30-2011 01:50 PM
  2. Moscow Desire's Avatar
    Rooted? Rommed?
    There are other music players in the Market.
    10-30-2011 02:33 PM
  3. ElefantPhace's Avatar
    What exactly do you mean by stop? As in not playing the next song, or stopping in the middle of one?
    10-30-2011 02:38 PM
  4. siwel1976's Avatar
    10-30-2011 02:42 PM
  5. siwel1976's Avatar
    It stop in the middle.
    10-30-2011 02:43 PM
  6. ElefantPhace's Avatar
    Does it report any errors? You're not giving us much to go on. Are you sure that the file you put on there is the full length song? Does the progress bar go all the way to the end or stop in the middle?
    10-30-2011 04:07 PM
