On Gingerbread 2.3.4 (in my case on a Galaxy S2 phone), if I've got it right, the USB and Internal SD are partitions of the standard 16GB of flash memory, yes? I believe USB has ~2GB, while the "SD" is 13-14GB.
I added a 32GB microSD card, which I'm guessing becomes the "External SD", is that correct?
Terminology aside, here's my issue ... when I move apps (using the native Gingerbread move2SD method) to SD card, they appear to be landing on the internal SD, and not the 32GB external SD. Is there a way to designate the external SD as the target for apps when moving them?
Thanks for any suggestions...
