Hello. I have an HTC incredible. Moved from blackberry. Is there any way to set the default for reminders in the calendar application to "none?"
It gives you options as low as 5 min to as high as it doesn't matter to me. I mostly but entries in without the need for a reminder. So needless to say I don't want to be bothered with removing them.
Nothing serious. But it would be great to not have to go and select the reminder and then select none.
