1. harry_fine's Avatar
    Have a Rogers SGS2 LTE. I have power saving mode enabled in the settings. It comes on at 30%, and shuts of wifi and bluetooth if not connected, dims the screen and reduces the screen time-out to 15 seconds.
    My question is this. Last night it went on at about 9 pm which was fine, and power lasted til I went to bed. In the morning after charging, the time-out is still at 15% and the bluetooth is still off. Does the power-saving mode not change the settings back to the original once the power is over the threshold, in my case 30%?
    Secondly, if I'm using a product like Juice Defender, should I be disabling the built-in power-saving mode and letting JD do it's work.
    Thanks
    Harry
    11-23-2011 09:20 AM
  2. pazzo02's Avatar
    The settings should go back to normal once it is above the threshold. Could be a glitch. Have you tried restarting? That usually fixes little glitches. I also use Juice Defender and have power saving mode enabled. I never thought about disabling it.
    fireidiot likes this.
    11-23-2011 10:17 AM
