While not unheard of, my particular situation may be a bit different from what I've already read about so I'll ask here just in case.
So recently I obtained a new 16 GB micro SD card which worked fine with my previous phone and typically worked well with my Galaxy SII as well, but when I went to transfer files from my computer to the card I ran into an issue. After all the files we're transferred it all seemed fine, but shortly afterward I ran into a blank SD card notification and was prompt to format via phone, which managed to format successfully. So then I went through the process again, this time putting nearly everything through a file converter before transferring. Again, everything seemed fine until a short while later when I have a blank card and prompt to format yet again. And like before the formatting seemed to work fine.
And to provide a bit more information that may be relevant, since our computer doesn't seem to play nice with my SD card (no window pops up after inserting and when attempting to read the card via My Computer it simply locks up and becomes unresponsive) when I transferred the files I did so through having my old phone plugged in with the card inserted and managed to get to it that way. With the second attempt I just used my current phone instead with hopes that it would work better that way. Unfortunately the same issue occurred as mentioned above.
So that pretty much covers it. If I had to guess it would seem that a hiccup is occurring with the transfer process that makes the card appear blank shortly afterward. Would be nice to find a way to prevent this from happening again.
