1. awd1315's Avatar
    I have a Motorola Photon HD dock, I LOVE my Photon but we no longer have Sprint service here (it will work for 3 months then out 3 months weird I know) so I also have Verizon and was thinking of getting the Droid Razr....question will the Razr work on the Photon's HD dock? If so how b/c aren't the ports different? Thanks for your help in advance!!!!
    12-22-2011 10:57 AM
  2. Moscow Desire's Avatar
    That, is a question nobody is willing to check.
    IF, and I mean IF, your + pins are the same with both, then you can try it without issues.
    But hey, suck it up and be a man. Plug that bad boy in, and see what happens.
    I would suggest you find the schematics first. But hey, sometimes, you just have to say,,, WTH...
    12-22-2011 11:31 AM
