Hey everyone, I was wondering if there was a way to re-install every stock application back onto the phone (bloatware and all.) I tried to upgrade to 6.11.748 but 25% through the installation I got the dreaded exclamation point and the phones says installation failed. I believe the problem is due to important missing system apps like Google Books, Guided Tours, etc. I have the full RAZR system dump files on my PC, is there a way to replace all current apps with the ones from the downloaded dump files? Is there a way to find out what system applications are missing and replace only those? I also have a Titanium Backup of my old files, although I am having issues installing system apps back onto the RAZR. Is there a way to force install the 6.11.748 update? I don't care about losing my root access, I am more concerned about the 3G/4G compatibility and camera bug fixes.. Factory resetting and trying the update does not work, unrooting and trying the update does not work, manually installing missing .apk's does not work.. I'm running out of ideas here, please help!
Thanks for all help in advance..
