Thank you! That was the solution. These forums have been a life savor.
Sent from my Droid Incredible using Tapatalk
Wow I did say thank you! Don't know why all the sudden these posts have been added. I am very grateful whenever I am helped. Is there a "thank you" button? If so I am sorry I didn't know.
Ok Dev, I thanked you!
But really, Dev is right, If people helped you, then, the best thing to do, is lay a Thanks. Don't just take your solution, and run.
Some of us, spend a lot of time helping people, Some, with very unusual issues that require e-mails, or PM's. We don't get anything for it. But hitting the THANKS button, is a little reward.
We're not blessed with being at the beginning of Android Central like the Mods, where every little tidbit was rewarded with several hundred Thanks at one time. Hence why some have a few thousand. Things have died out since the early days of Android.
But, when somebody gives you a solution to a PROBLEM, hit the THANKS button. It's the least you can do. Don't just run off to Mickey D's to celebrate.
Edit: okay I found the thanks button.
HA!
You will see a "Thanks" button at the bottom of each post a person wrote. Like a "thumbs up"
Don't worry about it. I thanked him for you.
And, it wasn't really directed at you. But more in general. Please don't take it the wrong way
No I didn't take it the wrong way. Just wanna make sure no one thinks I'm one of those idiots who doesn't appreciate help and also get all pissy when no one can help them. If it wasn't for this site I would be back to my Treo bc I didn't know all the amazing potential of android and was getting frustrated. Then I found this magical place of information and I've never looked back.
