Alright, I have somehow managed to turn off Mobile Data in such a way that I can no longer turn it back on. Bear with me.
(It's a Motorola Droid 3 running Android 2.3.4 if that helps)
I was in Canada for a few days, and I got a message that asked if I either wanted to use data roaming or if I did not want to use mobile data for the trip. I told it to not use mobile data, since I was just going to use wifi, but the message kept popping up every 5 minutes, interrupting whatever I was doing.
There was also a notification at the top of the phone when it popped up, and touching it brought me to a menu where I could disable data roaming (which did not stop the error messages) or disable mobile data entirely (which did).
However, when I got home, I could not find that menu again, or any settings menu that will let me turn mobile data back on. There is no option for it in Settings > Wireless & Networks > Mobile networks, or any other place that seemed related.
Any suggestions?
Any suggestions?
