1. dakota1820's Avatar
    Hi guys im new here my name is dakota. I am having an issue where my phone wont scroll accuratly. Ill go back to try to fix an issue say 3 lines up from where I am and it wont scroll to the correct place I tried to place it. also if you get the cursor where you want it to fix a mistake getting it to go back where you were typing before trying to fix the mistake is a headache. Itll recenter the screen once yoy try to click back to where you were typing so you cannot see where or what your typing. I currently havr the nexus s but my evo4g did it to. The nexus is worse though. Sometimes its fine but uaually it isnt.
    01-15-2012 05:51 PM
  2. sropedia's Avatar
    I have the same problem on my nexus, so I second that question
    01-15-2012 09:29 PM
