N Nooboid New member Jan 19, 2012 1 0 0 Visit site Jan 19, 2012 #1 I have an HTC Evo 4g with a 16gb sd card. I went from an 8gb to 16gb and my phone will not let me move any more apps to the sd card. Its currently using 7.2 gbs, only half full. Anyone else have this problem?
C Cellmeister Well-known member Jan 12, 2011 252 19 0 Visit site Jan 19, 2012 #2 back up your files to pc and then reformat the card on your phone not your pc check your manual or search evo forums for exact method and more info hope that helps
srkmagnus Retired Moderator May 23, 2010 13,434 210 0 Visit site Jan 20, 2012 #3 What the above post says to do. A format of the sd card should do the trick. Sent from my SPH-D710 using Tapatalk
C Cellmeister Well-known member Jan 12, 2011 252 19 0 Visit site Jan 21, 2012 #4 FYI; be sure to disconnect from PC using PC eject to avoid corruption (all the time) hope that helps
