1. jousty's Avatar
    Just got a razr maxx - Once I figure how to remove the microsd from the maxx (It's very tough to remove) I want to insert one I had in a Thunderbolt. What do I need to do to do so? I really just want my music and pics from the old phone...Any help would be appreciated
    02-03-2012 12:20 PM
  2. pazzo02's Avatar
    Once you put the new sd card in, format it. After that you should be good to go.
    02-03-2012 08:16 PM
