I'm looking for a theme or app or widget, whatever, that will show my calendar appts. on the lock screen. I'd really like to see at least a week in advance, without having to open my Vivid. Any help would be greatly appreciated. Thanks.
A lot of people like Widget Locker to display apps/widgets on the lock screen. You might want to see if it will display the calendar appointments like you are looking to do: https://market.android.com/details?id=com.teslacoilsw.widgetlocker&hl=en
I'd suggest sending the Developer an email or searching the web to see if you can display your appointments.
