screebl might be of use to this issue. it's an app that keeps the screen on when you have your phone at a certain angle (whatever you set it too). i use the free one and it works great. the paid one might work even better towards this concern, i think it lets you set what apps will leave the screen on when accessed. not to sure but its possible.
there probably are apps out there as well that might do exactly what you are looking for. i would google it and see what comes up
06-06-2010 01:01 PM
