1. jumbyhead's Avatar
    Hi, I rooted my phone a couple weeks back. I backed up my apps with titanium pro and downloaded ROM manager. I clicked "reboot into recovery mode" from ROM manager and the phone went into recovery.
    I am now stuck. I have four options:
    1. reboot system now
    2. apply update from SD card
    3. wipe data/factory reset
    4. wipe cache partition
    I tried option one and clicked the button on the right side of the phone (the "enter" button), but nothing happens. In fact, none of the options do anything. seems like the phone isn't recognizing the enter button.
    I have not flashed clockwork mod recovery.
    Can someone help me figure this out? I think it probably requires some type of reboot but i don't know the steps.
    Thanks
    03-07-2012 12:03 AM
  2. jumbyhead's Avatar
    03-07-2012 12:23 AM
  3. al.balushi's Avatar
    07-20-2012 10:51 AM
  4. Devinator's Avatar
    Thanks for posting your fix. Sorry that no one was able to help you.
    07-20-2012 12:31 PM
