is it possible..... anything is possible. is it likely... probably not. if it was done it would need a lot of work by a really experienced dev. it also could be really slow and laggy. if it was ported hypothetically i don't think it would be worth running. and on top of that i used to have a storm and i remember the memory was so low and it just wasn't designed well.
you could always put android on an iphone if you were interested
