1. pistos's Avatar
    In the Calendar, Month view, for ICS stock calendar, there is a little colored square placed to the left of each event you have scheduled on the calendar. My question is this: What is the meaning of a square being solid or an outline? What does a solid verses open square signify?
    Thank you for any help.
    I am using a Motorola Zoom, running OS 4.0.4
    04-19-2012 04:10 PM
  2. grunt0300's Avatar
    It means that you have an event scheduled on that day.
    04-19-2012 05:49 PM
  3. pistos's Avatar
    No. That is not what I am talking about. I know what it looks like if an event is scheduled on a day.
    Some events that are scheduled on a particular day have a solid square and some have an open square.
    04-19-2012 07:32 PM
  4. adavisme's Avatar
    I have been wondering this too.
    Why are some solid and some just an outline?
    06-05-2012 11:38 AM
  5. Igothakrull's Avatar
    Can you ad a pic for me to see? I have been looking for this in my calendar and can't see what you mean.
    Skickat från min Galaxy Nexus via Tapatalk 2
    06-06-2012 11:42 AM
  6. Insp_Gadget's Avatar
    All-day event vs timed event?
    06-06-2012 11:53 AM
  7. CycloneFever's Avatar
    Resurrecting this thread because I have the exact same question and I can't find an answer anywhere.
    In the monthly calendar view in ICS, events have a little colored square next to them to color code what calendar they are on. Some of them are solid squares and some of them are hollow (outline one) squares. What is the difference?
    I can't notice a distinction between all-day or timed events, one-time-only or recurring events, etc.
    In the day, week, and agenda views all the colored icons are solid.
    I do know that in the web app, appointments you don't have the ability to modify are cross-hatched. In this case these are all appointments I can modify so that isn't it.
    06-26-2012 07:48 PM
  8. kawana72's Avatar
    Could it be the calendar that created the event? I know that even though I'm on gingerbread, I have a few different colored calendars.
    Sent from my DROID RAZR MAXX using Android Central Forums
    06-27-2012 02:53 AM
  9. pistos's Avatar
    Nope, that isn't it.
    06-27-2012 04:31 PM
  10. crwallace2's Avatar
    I just ran a quick test, and it appears that events created or added through the web calendar interface are displayed as open squares and evens created from a mobile device and then synced to the calendar are displayed as solid squares. I tested by creating an event from my phone (HTC Thunderbolt) which then appeared as a solid square on my tablet ICS calendar. I also created a test event from my tablet which also appeared as solid. I then went to my computer and created another event from the web interface and it appeared as an open square on my tablets month view. I find it a little interesting and unexpected that it seems to have been designed this way but I guess its a nice feature if it had been documented a little better.
    Sent from my ASUS Transformer Pad TF300T using Tapatalk 2
    06-27-2012 10:10 PM
  11. pistos's Avatar
    crwallace2: I thought I had tested that once before, but maybe I hadn't. Your explanation makes the most sense. I am not sure why Google would include this "feature" though. I don't see an immediate use for it. Thank you for your help.
    06-27-2012 10:38 PM
  12. pistos's Avatar
    Good news... with the Jelly Bean upgrade that installed on my Xoom, this odd calendar issue is gone. All events are now shown with solid colored boxes in the month view. :-)
    07-28-2012 10:33 AM
