1. andrewsmart212's Avatar
    Hi,
    I got galaxy gio, which has Android 2.3.3, today at a worse moment of my life, I update my gio from Setting > About Phone > Update then it ask me for sign in, I login then it start updating after some time it says your phone is now restarting, then a 20 - 30 mints loading comleted and it stucks, then I restart it doesn't do anything, it only stucks at boot up screen, on that my screen just showing me Galaxy Gio S5660 and then nothing happened just stuck, I again restart but it stuck.
    now I want to restore it to factory setting by pc, if it possible, I thing i have disturb the OS so I can only restore it by from my PC.
    plz help I think i have lost my android
    05-17-2012 12:46 PM
  2. norparn's Avatar
    I have the same problem!
    No version of Odin helps!
    Heimdall does not help!
    To night I remove battrey and card's, if it starts up you will know....
    10-03-2012 01:16 PM
  3. norparn's Avatar
    Installed 2.3.6 2 weeks ago, it runs perfect and all apps works perfect to! :-)
    10-16-2012 04:53 PM
