Hey all, I have a question for you all. When I was going though my settings I noticed that I can turn GPS on. It says that GPS needs a view of the sky. I want to turn this on but I'm afraid it will go though my data (I have no data plan so if I do use 3G it is quite expensive). The odd thing is: GPS works even with 3G turned off, so at this point I'm very confused about wether it needs internet or not.
Thanks is advance!
Sent from my SGH-T589R using Android Central Forums
Thanks is advance!
