So, where do you guys recommend to get the 32GB MicroSD card. Somewhere cheap and safe.
Thanks in advance...
I wouldn't use "cheap" and "32GB microSD card" in the same sentence unless they're strung together with a "not".So, where do you guys recommend to get the 32GB MicroSD card. Somewhere cheap and safe.
