How to enable emoji's on OS 4.0
braxton355
252
28
I figured this out the other night. I'm not sure if it works on other devices I'm using an OV running cai. Like I said I didn't know about this until last night, and I'm sure there are plenty of you guys who haven't figured it out either. I hope I help.
INSTRUCTIONS: okay you won't need any messaging app other than stock. So go into your stock messaging app, and hit the menu button. Go into settings, and find emojis support, and check that. Then right above that (on my phone) check the option that says Unicode support. These options both are under extra settings!
Now to get the emojis go your messaging, go into a new message or one that your already talking to (your girl ;), hit the menu button and it gives the option the insert smiley's and the option to insert emojis! The rest is easy :)
HOPE I HELPED.
