1. roolala's Avatar
    Hello everyone. I'm new to Android and loving it so far, but I've got an issue with my new phone.
    I got an HTC Raider on the weekend, and while using the 3G/4G/LTE networks, it's amazing. Super fast and wonderful. Also, generally, while using wifi it's the same thing - fast and works perfectly.
    However, when I'm at work, and I connect to the wifi network at my office, it will typically only work for 3 or 4 minutes, and then just stops working. It still displays maximum signal strength, but won't load any page on the internet, and any apps that send/receive data do not work. My work computer is also on the same wifi network and it always works no problem, so I know the wifi network is fine.
    So the issue is that my phone will connect to my work wifi but only for a few minutes at best. Why is this happening and is there something I can do/change to help the situation?
    (I should note that the phone works on my home wifi [and restaurant wifi] networks just fine)
    06-07-2012 12:55 PM
  2. Clutchgear's Avatar
    My wifi or 4G will stop working temporarily as well on my HTC raider. It only started happening after the recent software upgrade. I have to remove the battery and reinstall it then the phone returns to normal. Not sure if this is the same problem you are having.
    07-22-2012 09:55 AM
  3. Va1ha11a's Avatar
    It could be a bug with your software update. YOu may want to contact HTC support online.
    07-22-2012 02:59 PM
