1. mattmanne's Avatar
    Hi everyone,
    My wife recently broke the screen on her T-bolt, and her contract isn't up. I'm looking to get her a new or slightly used Razor Maxx. What sites would you all suggest?
    Is Ebay/Craigslist a good move? Are there other sites that would be better? I don't mind paying for it, but would like a good deal if possible. Most importantly, I don't want to get screwed or buy a stolen phone.
    Thanks for the help
    06-18-2012 12:03 PM
  2. SellnCLT85's Avatar
    I would recommend to check out a Site called http://swappa.com/?ref=mobilenations...cUvbUpU1863260. Alot of Devs use the Site to pick up devices.
    Sent from my ADR6400L using Xparent Blue Tapatalk 2
    06-18-2012 01:58 PM
  3. Ry's Avatar
    There's a marketplace forum here.
    Sent from my DROID BIONIC using Android Central Forums
    06-18-2012 02:02 PM
