1. caryniam8's Avatar
    I had a weird problem that happened twice today. The phone was on but in sleep mode, and the screen was black. Pressing the top button would not tun the screen on. I pressed it multiple times. Touching the screen did nothing. I couldn't turn it off b/c you need to do it from the home screen.
    I had to remove the battery and turn the phone back on for it to work. This has happened twice today.
    Has anyone had this problem? Thoughts?
    06-16-2010 10:55 PM
  2. terpitude71's Avatar
    I have had that issue a few times with my moto droid (not for a while though come to think of it). Not sure what caused it; just rebooted the phone and it would be fine
    My only suggestion is that an app could be causing it. If you suspect a recently installed app is causing it, uninstall that app for a day and see if you run into that problem. Then reinstall the app and see if your phone freezes on you again
    06-17-2010 12:15 AM
