1. aequitasXI's Avatar
    This is very odd. I can send MMS messages perfectly fine, but if someone tries to send me one I get nothing. No notification or any way of knowing I didn't get it unless someone tells me they tried to send me one.
    I see in the GO SMS settings the MMS part is in Red, but there don't appear to be any settings to resolve the issue.
    Any ideas?
    Sent from my Droid RAZR MAXX
    07-18-2012 09:42 PM
  2. Zhara's Avatar
    Did you disable or uninstall the stock messaging app?
    07-18-2012 10:08 PM
  3. aequitasXI's Avatar
    Yes, I'm on ICS, so I was able to disable the stock messaging app.
    07-19-2012 06:00 AM
