1. basil60's Avatar
    I hope this is the right place to post. Google search steered me this way, so...
    I accessed my Google Play account from my daughters phone, to download an app for her. I unticked the option to automatically download emails (or something similar).
    But, she's getting all my GMails automatically downloaded onto her phone.
    Where do I go to change the configuration - so the only place my GMails go is my phone?
    Cheers
    07-21-2012 01:58 AM
  2. afranko22's Avatar
    If you open the gmail app and go to settings, you should see an option to make changes to your email account. You can remove it this way or set the downloading options. Hope this helps.
    Sent from my Verizon Droid Razr Maxx
    07-21-2012 04:16 AM
