Like I said,I don't use the phone memory. I have NOTHING on my phone,other than what it came with. I assume the pictures/videos are on the sd card,but I could be wrong,but even so,I barely have any to begin with. Well,I've been told,that there are three spots of memory/storage on a phone: The SD card,the phone memory,and another storage unit attached to the phone memory. The last one is used for actual app memory IE:Game data,browser history,etc. And I've heard that rooting your phone,can make that last storage unit larger,or even move it to the SD card instead using the phone memory. and that you can delete useless storage from it. My phone is an LG -MS690,Android version 2.2.2 if that's enough info. I got the cache cleaner app AFTER the issue started happening. help? o_o
Well, when you say memory, are you talking about the internal storage?
Check to see where your pics and whatnot are being stored. They could be being stored on internal and that might account for your problem. If you go into settings in camera, you should be able to check the setting. Alternatively, you could just plug the phone in VIA USB and check, but, that would seem slower.
Well, there should be three storage places. Reserved internal storage for the OS, internal storage for apps, pics, etc., and your SD card.
I dunno, I guess it's possible that flashing a custom ROM could increase OS internal storage, but, how much could it really be increased by? Not much I'd say, so, I don't see how that's gonna help you.
Can you shoot a link for the phone? I just wanna see how much storage it has. My phone's internal has 8 GB and I store all the apps on it and have never had any issues. Not trying to say your issue isn't valid though.
Oh,and I forgot to add,I already have all my apps on my SD card. I promised myself,I wouldn't download/keep any that couldn't be transfered to the SD card for the fact of the storage issue. I can't download any apps,nor receive/send any Texts while this issue is happening.
Okay, that's weird. Unless you have like 1 GB of internal storage, I don't see how it could be an issue. Maybe it's something with your email? How much data is listed under Gmail when you go into Manage Apps? Or what about text messaging? How much data is listed there?
I hate to say it, but, a reset might be the easiest way to resolve the whole issue. That way you don't keep banging your head against the wall about it. :-\
