Hi - I can't find my phone on this forum so I'll have to post here.
I've just got a Galaxy S Advance from Virgin Mobile (UK) and it has a load of pre-loaded cr@ppy games and apps I want to remove but cannot do so through the phones own settings.
I read somewhere else that I needed to install Busybox and SuperUser which I have done but there were no further instructions as to what to do next to remove the offending apps.
Can anybody help with what I need to do now?
Also, my phone will no longer shut-down. When I attempt to shut-down it just reboots.. very annoying. Maybe this is because I installed Busybox and SuperUser? Is there a way to restore to factory settings?
Thanks.
Thanks.
