When using Google Maps Navigation, how do you get it so as you're following the directions the maps is viewed at and angle so you can see further ahead on the map. Also how do you have the screen/map turn as the car turns?
Right now it's just looking down and with no angle/tilt on the arrow and the orientation stays "north up" all the time. It used to do this.
I'm still new to Android, so maybe I missed a setting or something.
