1. jmt8669's Avatar
    Is there any way to have my wifi automatically turn off when i leave my home wifi connection? I'm trying to not have it continue to search for signal ans drain bay when not in range at home
    Sent from my DROID RAZR using Android Central Forums
    07-26-2012 08:00 PM
  2. piizzadude's Avatar
    you can use an app called tasker...there is a learning curve to it but it will do the trick
    07-26-2012 08:04 PM
  3. taylorz_412's Avatar
    I see you have a RAZR look in the smart actions on your phone and there should be a way to that it will shutoff WiFi automatically when your not in range of your home router
    GSIII VZW via tapatalk 2
    07-26-2012 09:20 PM
  4. jmt8669's Avatar
    Thanks to both of u
    07-27-2012 12:16 PM
