1. chrissv's Avatar
    Hi All,
    My wife has a Samsung Galaxy S2 (T-Mobile), and it was working just fine. Now all of a sudden, a strange screen shows up whenever she presses the home button (see attached). It has a "close" button in the upper corner, and when she presses it she sees her traditional screens of applications. But pressing the home button brings it back.
    I can't find any app that has taken over the home button; nor does she say she loaded any new apps (I checked as well).
    Can anybody identify this screen?
    Thanks - Steven
    07-28-2012 09:17 PM
  2. sropedia's Avatar
    She's on car mode. When it's active it replaces your home screens with apps the phone thinks you might use while driving. To turn it off, either press back until it asks you to confirm exit or press menu and there should be an option to exit car mode (its different on some devices) good luck
    Sent from my HTC EVO 4g LTE (3g only model!)
    07-28-2012 11:10 PM
  3. sropedia's Avatar
    I could always be wrong though
    07-28-2012 11:13 PM
