Ok currently on Windows 7 64bit, have the Incredible for the phone. Have Bluetooth software on my PC and is set to allow devices to discover the PC as well as allow remote access to browse, send, and receive pics, music, and other files.
Ok so here is my issue, when on phone and I scan for devices it finds my PC. Pairing or trying to Pair & Connect takes 15-30 secs then I get phone prompt to enter a pin (It suggest using 0000 or 1234) nothing works, PC doesn't get any prompts.
Now when I try to add device from bluetooth taskbar menu, it finds the phone but after 2 minutes saids couldn't connect.
Please help in my guidance in what I'm missing here, so I can send files over Bluetooth. Thank you
