1. Terrjbrennan's Avatar
    my LG Phoenix's screen won't turn on. The buttons do but the screen is completely blank. There are no sounds either, and the phone is completely charged. I have restarted it and taken the battery out for 30 seconds but its not helping, what should i do? P.S i'm expecting an important call soon so i need to fix this
    07-31-2012 12:02 AM
  2. piizzadude's Avatar
    normally I wouldnt recommend this first off, but if you have to have the phone right now, a hard reset might help LG Phoenix P505 Android hard reset - PDA Smartphone PNA hard reset soft reset
    07-31-2012 12:06 AM
