1. crashpete's Avatar
    I can't port my number to Verizon or Google voice, both from sprint, is there a third option? This is for a new galaxy s3 on Verizon.
    07-31-2012 02:39 PM
  2. EvilMonkey's Avatar
    Why can't you? I just did that a couple of weeks ago (ported from Sprint to Google voice)
    I'd be happy to walk you through what I did...I made a few assumptions and mistakes, so maybe you can learn from me.
    Do you currently use the Sprint integration with Google Voice?
    07-31-2012 07:57 PM
  3. crashpete's Avatar
    Because of the area code, verizon and google won't touch it. No to the second question. It's the main reason I didn't try verizon. Until now.
    08-01-2012 01:59 AM
