1. Karlam1991's Avatar
    I want to buy full price samsung galaxy s3 to use with my tmobile prepaid plan will that work ? If so how do I activate it..i would appreciate it if anyone knows anything...
    Sent from my SGH-T499 using Android Central Forums
    08-01-2012 09:41 AM
  2. piizzadude's Avatar
    call t-mobile to be sure, but the quick google i did says you should be able to, either with their phone or by buying an unlocked international version
    08-01-2012 10:33 AM
  3. Karlam1991's Avatar
    Thank you so much. I will call them.
    08-01-2012 10:39 AM
